[mapguide-trac] #522: MapGuide Crash on Linux
trac_mapguide at osgeo.org
Fri Apr 4 01:53:04 EDT 2008
Reporter: Rothgar | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: Server | Version: 2.0.0
Severity: critical | Resolution:
Keywords: | External_id:
Changes (by jng):
* severity: blocker => critical
Comment:
I've done some tests myself and the crashes occur when previewing the map.
But I can't produce a result, because it happens at random. The tests I've
done:
1) run normal mgserver.sh, got it to crash on map preview with that exact
crash dump.
2) run mgserver.sh through gdb, previewed many times without crashes.
3) run normal mgserver.sh again, piping output to a text file. Still can't
crash it.
4) run normal mgserver.sh again, can't crash it.
I did notice the IP of the mysql server was not correct and changed it to
the correct one. But this isn't the source of the problem, as I ran the
tests after the IP change.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/522#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
