[mapguide-trac] #295: MapGuide fails to locate the correct
fonts in Ubuntu Linux
trac_mapguide at osgeo.org
Wed Apr 9 18:59:58 EDT 2008
#295: MapGuide fails to locate the correct fonts in Ubuntu Linux
Reporter: jng | Owner:
Type: defect | Status: closed
Priority: medium | Milestone:
Component: General | Version: 2.0.0
Severity: major | Resolution: invalid
Keywords: | External_id:
Changes (by tomfukushima):
* status: new => closed
* resolution: => invalid
Comment:
Hi, Actually, this workaround specified of putting the fonts in the bin
directory, is the correct way of installing fonts for !MapGuide. It does
not know about other fonts on the system. I'm closing this defect, but if
you would like to fix it, I suggest changing it to an enhancement: MGOS
should find fonts on Linux.
Also, if you have documentation on how to handle fonts on Linux that shows
that this enhancement is in fact possible, that would be helpful.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/295#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
