[mapguide-trac] #535: Update area stylization code
trac_mapguide at osgeo.org
Fri Apr 18 19:04:22 EDT 2008
Reporter: waltweltonlair | Owner: waltweltonlair
Type: defect | Status: new
Priority: high | Milestone: 2.1
Component: General | Version: 2.0.0
Severity: major | Keywords:
External_id: 1067431,1067434 |
The existing code which applies area styles (in SE_AreaPositioning) has a
number of bugs. It's also not documented very well.
I've gone through the code, and rewrote it for the most part. I also did
extensive testing to verify the code is stable.
A number of bugs have been fixed:
* the code no longer hangs with area styles that have an angle
* negative repeats are correctly handled
* the generated symbol grid distribution now more closely matches the
input feature geometry (fewer symbols are drawn overall)
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/535>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
