[mapguide-trac] #539: Implement CLIENTIP and CLIENTAGENT tracking
in the Server's Access.log
trac_mapguide at osgeo.org
Fri Apr 25 16:03:10 EDT 2008
#539: Implement CLIENTIP and CLIENTAGENT tracking in the Server's Access.log
Reporter: tonyfang | Owner: tonyfang
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: Web API | Version: 2.0.0
Severity: minor | Keywords:
External_id: |
The CLIENTIP and CLIENTAGENT parameters must be sent to the server in
order for the Access.log to record them. Currently, only the Map Admin php
application is doing so.
The following changes are needed:
* The Apache/ISAPI/CGI agent needs to figure out the IP address from the
REMOTE_ADDR CGI Server variable and send it to the server. This takes care
of the IP address for http server requests.
* When a web application (like the Map Admin, Ajax Viewer, Fusion Viewer,
Schema Report) creates an MgSiteConnection, the MgUserInformation should
also set the Client IP and Client Agent. Currently, this was only
happening for the Map Admin.
* When a web application (Ajax Viewer, Fusion Viewer) makes an http server
request, it needs to set the CLIENTAGENT parameter.
* The web tier test pages need to also send the CLIENTAGENT parameter with
its server requests. We will add editable textboxes for this parameter to
be consistent with the other parameters.
Notes:
* The Fusion Viewer changes will be made to the Fusion vault.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/539>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
