[mapguide-trac] #530: Site Administrator "About" page does not
show server version
trac_mapguide at osgeo.org
Fri Apr 25 17:38:10 EDT 2008
#530: Site Administrator "About" page does not show server version
Reporter: jbirch | Owner: ronnielouie
Type: defect | Status: new
Priority: medium | Milestone:
Component: Map Admin | Version: 2.0.0
Severity: minor | Resolution:
Keywords: | External_id:
Comment (by ronnielouie):
The exception message you are getting is consistent with behaviour when
$userInfo has not been set. It seems for some reason, it is not correct
only when accessed from your about.php page. But for everywhere else
where you encounter it, sounds like it is fine. I assume you are clicking
on the About link from the Site Admin pages, or have a valid a session
with Administrator user if you are trying to hit it directly via
http://localhost/mapguide/mapadmin/about.php. The only way I can
reproduce it if I try to hit the page without first having a valid session
available.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/530#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
