[mapguide-trac] #530: Site Administrator "About" page does not
show server version
trac_mapguide at osgeo.org
Tue Apr 29 17:18:42 EDT 2008
#530: Site Administrator "About" page does not show server version
Reporter: jbirch | Owner: ronnielouie
Type: defect | Status: new
Priority: medium | Milestone:
Component: Map Admin | Version: 2.0.0
Severity: minor | Resolution:
Keywords: | External_id:
Comment (by ronnielouie):
Added code to check if server is up, and also display errors in About
page.
This defect is easily reproduced when there are two different versions of
MG on the same machine (ie. MGOS 1.2 and MGOS 2.0). Stop the MGOS 1.2
server and Start the MGOS 2.0 server and login to Site Admin. Click the
about button to verify that the Server version is correctly displayed.
Stop the MGOS 2.0 Server and start the MGOS 1.2 Server. Login to Site
Admin and click on the About button. Server version will display ?.?.
Also test the above by pointing to
http://localhost/mapguide/mapadmin/about.php. If
Administrator has not been logged in for a session, the version will
display ?.?, otherwise, if the 2.0 server is running, the version should
be correctly displayed.
http://trac.osgeo.org/mapguide/changeset/3143
Note: This submission does not fix Jason's problem with $userInfo in IE6/7
as I have not yet been able to reproduce it.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/530#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
