[mapguide-trac] #652: Maestro: Warn user when adding a raster
layer to a map with a different coordinate system
trac_mapguide at osgeo.org
Wed Aug 6 03:18:02 EDT 2008
#652: Maestro: Warn user when adding a raster layer to a map with a different
coordinate system
Reporter: jbirch | Owner: ksgeograf
Type: enhancement | Status: assigned
Priority: medium | Milestone:
Component: Maestro | Version:
Severity: minor | Resolution:
Keywords: | External_id:
Changes (by ksgeograf):
* status: new => assigned
Comment:
Yes. Nice idea. It is indeed possible to detect if the layer is a raster.
There will be a small overhead when adding the layer, due to a call to
"DescribeSchema" for getting the coordinate system.
I will also add a check to see if the extent reported by the provider is
the (-1000000,-1000000,1000000,1000000) extent, which is sometimes a
masked error, and in any case, not likely to be a valid bound.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/652#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
