[mapguide-trac] #657: Unable to load php_MapGuideApi.dll when there are multiple PHP directories in the system PATH
MapGuide Open Source trac_mapguide at osgeo.org
Fri Aug 8 18:19:04 EDT 2008
in the system PATH
 Reporter:  ronnielouie  |         Owner:  ronnielouie
     Type:  defect       |        Status:  new
 Priority:  medium       |     Milestone:  2.1
Component:  Web API      |       Version:  2.0.1
 Severity:  major        |    Resolution:
 Keywords:               |   External_id:  1063001
Comment (by ronnielouie):
 Renamed php_MapGuideHelper to phpMapGuideApiEnvConfig.  See r3266.
 Remaining tasks for this ticket are to update the installer for windows to
 include the new extension, update the php.ini file to load the extension,
 and to no longer add PHP to the system PATH.
 Also the
 [http://mapguide.osgeo.org/sites/mapguide.osgeo.org/files/BuildingAndConfiguringMGOSOnWindows.pdf
 Building and Configuring MGOS on Windows document] should be updated to
 add instructions for loading the new extension via php.ini and to omit the
 step for adding PHP to the PATH.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/657#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
