[mapguide-trac] #675: HttpServerConnection.RenderRuntimeMap()
fails...
trac_mapguide at osgeo.org
Mon Aug 25 05:53:36 EDT 2008
#675: HttpServerConnection.RenderRuntimeMap() fails...
Reporter: MaksimS | Owner: ksgeograf
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: major | Resolution:
Keywords: | External_id:
Comment (by ksgeograf):
I think I've found the problem.
For some reason the Flush() call does not wait until the data is written.
When the stream is disposed/closed, there are still data waiting.
I think this is very machine specific, and I have never seen it myself.
I have re-arranged the code a bit to prevent this situation.
If you check out the latest version of the code, it should be fixed.
I think that the "Print" command uses the GETMAPIMAGE.
What call for getting !RuntimeMap issues all these DESCRIBEFEATURESCHEMA?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/675#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
