[mapguide-trac] #675: HttpServerConnection.RenderRuntimeMap()
fails...
trac_mapguide at osgeo.org
Mon Aug 25 06:51:47 EDT 2008
#675: HttpServerConnection.RenderRuntimeMap() fails...
Reporter: MaksimS | Owner: ksgeograf
Type: defect | Status: assigned
Priority: low | Milestone:
Component: Maestro | Version:
Severity: major | Resolution:
Keywords: | External_id:
Changes (by ksgeograf):
* status: new => assigned
Comment:
Yes, that might be why I have never seen the problem. I have tried on
remote servers, but probably never called GetMapImage on such a
connection.
The CreateRuntimeMap calls Describefeatureschema for each layer that is
selectable. The runtime map must contain the primary key for the layer
features to be selectable.
Do you have the same layer included many times in the map?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/675#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
