[mapguide-trac] #680: Error saving Fusion layout..
trac_mapguide at osgeo.org
Tue Aug 26 08:31:20 EDT 2008
Reporter: andrewd | Owner: ksgeograf
Type: defect | Status: closed
Priority: high | Milestone:
Component: Maestro | Version:
Severity: critical | Resolution: worksforme
Keywords: | External_id:
Comment (by andrewd):
I just wanted to publish the solution to this...Since WebLayouts supported
the "&" sign in parameters, I thought I'd check the XML for an existing
WebLayout of mine to see how it was stored. It's stored as "&" in the
XML. So the solution (which works MUCH better for my case - the other way
would involve some extreme php script revising) would be to simply type in
"&" instead of "&". I'd tried "&", but that didn't work - you need
the semi-colon.
So - to sum up...in Fusion widgets, use "&" instead of "&".
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/680#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
