[mapguide-trac] #423: Unhandled exception previewing ODBC source
when joined source is previewed
trac_mapguide at osgeo.org
Thu Feb 7 15:55:59 EST 2008
#423: Unhandled exception previewing ODBC source when joined source is previewed
Reporter: ronnielouie | Owner: ronnielouie
Type: defect | Status: new
Priority: medium | Milestone: 2.0
Component: Server | Version: 2.0.0
Severity: major | Keywords:
External_id: |
1. Join an SDF feature source to an ODBC feature source (defect can be
reproduced with Access database).
2. Open the primary feature source and preview it. View the data on the
joined feature class.
3. Open the ODBC feature source and preview it. An unhandled exception
occurs. Error in the server logs indicates a File I/O error.
Problem is not confined to ODBC. If cache is enabled for SDF, the same
behavior will occur when performing a DescribeSchema on the feature
source, and then attempt to copy the feature source.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/423>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
