[mapguide-trac] #425: DWF Viewer stops responding after 60 seconds
idle when connected to server with HTTPS (SSL) connection
trac_mapguide at osgeo.org
Fri Feb 8 12:04:26 EST 2008
#425: DWF Viewer stops responding after 60 seconds idle when connected to server
Reporter: ronnielouie | Owner: ronnielouie
Type: defect | Status: new
Priority: medium | Milestone: 2.0
Component: Map Agent | Version:
Severity: major | Keywords:
External_id: 950764.02 |
Configure a MapGuide server (web tier) with an SSL certificate, and
configure IIS/Apache to serve the MapGuide site with https.
View a map on the server using the DWF Viewer (version 7). Zoom in and pan
around, noting the response rate of the application.
Leave the DWF Viewer idle for at least 60 seconds (i.e., no zooming,
panning or any other activity). After waiting, try to zoom or pan the map.
Expected result: The map to be zoomed or panned with the same performance
as when you first started testing it.
Actual result: Refresh status bar displays and the cursor turns to an
hourglass. This state remains for between 90 and 120 seconds, then the
status bar disappears and the cursor reverts to its normal state. The map
does not update. Any attempt to pan or zoom will then cause the viewer to
lock up.
Note: If you click REFRESH after the 60 second period, you can pan and
zoom as normal. The problem is that this action resets the scale and view
to the default state.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/425>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
