[mapguide-trac] #413: Feature Joins totally broken
trac_mapguide at osgeo.org
Sun Feb 10 19:58:54 EST 2008
Reporter: jng | Owner: brucedechant
Type: defect | Status: reopened
Priority: high | Milestone: 2.0
Component: General | Version: 2.0.0
Severity: blocker | Resolution:
Keywords: feature join | External_id:
Comment (by brucedechant):
I have attached 2 pictures showing both the preview of the above joined
feature sources and a map using this layer. However, I did notice that it
took a considerable amount of time for the image to actually appear
(several minutes). So I believe joins are working correctly just that in
this case performance is slow.
A new defect to address the performance issue should be created.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/413#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
