[mapguide-trac] #382: Implement RFC 43 - Support Search and Selection on Double Identity Properties
MapGuide Open Source trac_mapguide at osgeo.org
Wed Feb 13 12:02:06 EST 2008
Properties
 Reporter:  trevorwekel  |         Owner:  trevorwekel
     Type:  defect       |        Status:  reopened
 Priority:  medium       |     Milestone:  2.0
Component:  General      |       Version:  2.0.0
 Severity:  major        |    Resolution:
 Keywords:               |   External_id:  1015380
Changes (by trevorwekel):
  * status:  closed => reopened
  * resolution:  fixed =>
  * external_id:  => 1015380
Comment:
 Previous submissions fixed search and selection for Double identity
 properties.  However further investigation has turned up failures with
 Int64, Single, and DateTime identity properties.  Also, feature classes
 with multiple identity properties are not supported.
 All of the above cases can be supported without changing public API.
 Additional submissions will be made to correct these defects.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/382#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
