[mapguide-trac] #440: Outer join doesn't create correct query results when primary key is NULL
MapGuide Open Source trac_mapguide at osgeo.org
Fri Feb 15 01:12:14 EST 2008
   Reporter:  brucedechant     |       Owner:
       Type:  defect           |      Status:  new
   Priority:  high             |   Milestone:  2.0
  Component:  Feature Service  |     Version:  2.0.0
   Severity:  major            |    Keywords:
External_id:                   |
 If the primary join key in a join is NULL the join fails to create the
 correct query results. The join results are missing records.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/440>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
