[mapguide-trac] #440: Outer join doesn't create correct query
results when primary key is NULL
trac_mapguide at osgeo.org
Fri Feb 15 01:48:01 EST 2008
#440: Outer join doesn't create correct query results when primary key is NULL
Reporter: brucedechant | Owner: brucedechant
Type: defect | Status: closed
Priority: high | Milestone: 2.0
Component: Feature Service | Version: 2.0.0
Severity: major | Resolution: fixed
Keywords: | External_id: 964898
Changes (by brucedechant):
* status: assigned => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/440#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
