[mapguide-trac] #443: Allow disabling of new vector symbolization lines / areas
MapGuide Open Source trac_mapguide at osgeo.org
Mon Feb 18 13:53:14 EST 2008
   Reporter:  waltweltonlair  |       Owner:  waltweltonlair
       Type:  defect          |      Status:  new
   Priority:  high            |   Milestone:  2.0
  Component:  General         |     Version:  2.0.0
   Severity:  major           |    Keywords:
External_id:  1047127         |
 New vector symbolization lines and areas still have some stability issues,
 and we need to disable them by default.  When the user defines layers
 using vector symbolization styles (e.g. using !SetResource and providing a
 !LayerDefinition-1.2.0 schema compliant XML document):
 1) If there is line stylization, it will be ignored and the lines will
 render as solid black lines.
 2) If there is area stylization, it will be ignored and the areas will
 render with a black border and empty (transparent) fill.
 Since line styles were semi-supported in !MapGuide 1.2 we provide a server
 configuration setting - !EnableVectorSymbolizationLines - that lets you
 turn them back on.  By default this setting is disabled.
 Line / area styles will still be enabled in the debug configuration so
 that development can easily continue.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/443>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
