[mapguide-trac] #448: Unexpected behavior when selecting features from an ODBC (MS Access) feature source
MapGuide Open Source trac_mapguide at osgeo.org
Thu Feb 21 14:15:05 EST 2008
feature source
   Reporter:  ronnielouie  |       Owner:  ronnielouie
       Type:  defect       |      Status:  new
   Priority:  medium       |   Milestone:  2.0
  Component:  General      |     Version:  2.0.0
   Severity:  major        |    Keywords:
External_id:  1048013      |
 1. Connect to a database using "Data connection..."[[BR]]
 2. In window "Connect to Data", select the feature provider "OSGeo FDO
 Provider for ODBC", click OK[[BR]]
 3. In tab window "New Feature source", select "Type of connection" (DSN or
 external file)[[BR]]
 4. In tab window "New Feature source", select the database to connect
 with.[[BR]]
 5. In tab window "New Feature source", define geometry properties to
 create spatial feature classes for the table.[[BR]]
 6. In tab window "New Feature source", in Preview pane, click View
 Feature.[[BR]]
 Try to select objects in AJAX viewer or Flexible layout viewer.  Notice
 selection will work if selecting a small number of features.  When
 selecting a large number of features, AJAX viewer will select all features
 on the layer.  Flexible layout viewer will not select any features.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/448>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
