[mapguide-trac] #451: Server can sometimes not set a FDO connection
as no longer in use
trac_mapguide at osgeo.org
Fri Feb 22 13:46:09 EST 2008
#451: Server can sometimes not set a FDO connection as no longer in use
Reporter: brucedechant | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.0
Component: Server | Version: 2.0.0
Severity: critical | Keywords:
External_id: |
Certain internal methods inside the server were not properly dereferencing
the FDO connection being used and this would cause the server to think a
FDO connection was still in use even though it really wasn't. This can
eventaully cause the server to quickly run out of available FDO
connections.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/451>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
