[mapguide-trac] #452: RESAMPLE bounds not used as spatial query
MapGuide Open Source trac_mapguide at osgeo.org
Fri Feb 22 14:01:35 EST 2008
   Reporter:  trevorwekel      |       Owner:  trevorwekel
       Type:  defect           |      Status:  new
   Priority:  medium           |   Milestone:  2.0
  Component:  Mapping Service  |     Version:  2.0.0
   Severity:  major            |    Keywords:
External_id:  1051068          |
 Some raster providers do not use the bounds of the RESAMPLE Fdo command as
 a spatial query when processing raster data sources.  This leads to slow
 performance with large datasets as each raster file is tested against the
 bounds of the RESAMPLE.
 By manually including the spatial query in the !FeatureService request,
 performance is improved.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/452>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
