[mapguide-trac] #457: SWIG string conversion for Java may not work on all JVMs
MapGuide Open Source trac_mapguide at osgeo.org
Sun Feb 24 21:42:47 EST 2008
   Reporter:  tomfukushima  |       Owner:
       Type:  defect        |      Status:  new
   Priority:  medium        |   Milestone:  2.1
  Component:  General       |     Version:  2.0.0
   Severity:  major         |    Keywords:
External_id:                |
 A pitfalls page from java.sun.com indicates that JNI native strings are
 not null terminated.
 http://java.sun.com/docs/books/jni/html/pitfalls.html
 The current SWIG translation from Java to C++ assumes that they are.  If
 this is true, the Java API should be completely unusable.  However, Tomcat
 does seem to work just fine.  Different JVMs may also behave differently.
 The offending code is the autogenerated string handling going from Java ->
 C++.  It can be easily fixed and will affect all CREFSTRING arguments in
 the API.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/457>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
