[mapguide-trac] #459: mgserver locks up when using AGG renderer
trac_mapguide at osgeo.org
Mon Feb 25 19:27:02 EST 2008
Reporter: jbirch | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: General | Version: 2.0.0
Severity: major | Keywords:
External_id: |
In some cases, when zooming to large scales (depends on dataset and screen
size), mgserver.exe enters a state where it locks up. It consumes 98%
cpu, and can not be terminated with a ctrl-c when run interactively. This
only occurs when using the AGG renderer; switching to GD prevents this
behaviour.
The attached (or maybe hyperlinked if it's too big) data set can be used
to exhibit this problem:
- Load the package hanging_ajax.mgp
- In Studio, open the weblayout to !Library://ccgismap-
ext/test/Layout/error_test
- Preview this layout in the AJAX viewer (from the link in the layout
editor) and use the mouse wheel to zoom in in increments until the server
stops responding.
- you may notice that at a particular scale, the feature no longer
renders, though the server still responds. I saw this behaviour at about
1:100 on my 1280x1024 screen.
This problem was initially found by Jonathan Manafi, and has been verified
by Jason Birch, for MGOS 2.0 RC4.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/459>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
