[mapguide-trac] #464: Selected objects do not display attributes, RC4
trac_mapguide at osgeo.org
Tue Feb 26 22:11:30 EST 2008
Reporter: amorsell | Owner:
Type: defect | Status: new
Priority: high | Milestone:
Component: Fusion | Version: 2.0.0
Severity: critical | Keywords:
External_id: |
With flexible layouts, when using the selection tool, no attributes for
the selected object (which always highlighted properly) were visible in
the Selection Panel, although the layer and number of selected objects
were properly displayed. This was the case for any layer source,
including the Sheboygan samples. Selection attributes work fine in the
properties pane in standard layouts still.
The test platform is a VMWare instance running Windows XP, using the .NET
web extensions, and testing with IE and Firefox.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/464>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
