[mapguide-trac] #468: Fusion doesn't use tile cache for ajax tiled
maps
trac_mapguide at osgeo.org
Thu Feb 28 23:35:33 EST 2008
#468: Fusion doesn't use tile cache for ajax tiled maps
Reporter: zspitzer | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.0
Component: Fusion | Version:
Severity: major | Keywords:
External_id: |
Fusion in RC4 is not using the Tilecache for maps with base layer groups
The openlayers mapguide layer support does support using tiled maps
I created a tiled map and then created flexible and static weblayouts
The static version called GETTILEIMAGE whereas the Fusion version use
GETDYNAMICIMAGE
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/468>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
