[mapguide-trac] #322: Fusion: ApplicationDefinition.xml files for each template refers to a non-existent map (SheboyganOverview)
MapGuide Open Source trac_mapguide at osgeo.org
Thu Feb 28 23:43:25 EST 2008
 Reporter:  jng      |         Owner:  pagameba
     Type:  defect   |        Status:  new
 Priority:  medium   |     Milestone:  2.0
Component:  Samples  |       Version:
 Severity:  minor    |    Resolution:
 Keywords:           |   External_id:
Comment (by jng):
 Just installed the 2.0.0 release.
 The ApplicationDefinition.xml files for each template still has the
 invalid map resource id. All templates except Slate still complain.
 The same xml files in the trunk still have the invalid map references.
 Either remove the invalid map reference, or actually have the
 SheboyganOverview map definition as part of the sample data.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/322#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
