[mapguide-trac] #469: Fusion Tiled Maps Issues
trac_mapguide at osgeo.org
Fri Feb 29 03:01:44 EST 2008
Reporter: jbirch | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Fusion | Version: 2.0.0
Severity: major | Keywords: fusion, tiled
External_id: |
Tiled maps in Fusion do not appear to be fully supported yet.
To test these, modify Aqua's ApplicationDefinition.xml, changing to the
map to MapsTiled\Sheyboygan, and setting SingleTile to false. All of
these were tested in FireFox.
1. Zoom slider does not appear to initialize. Stays on closest zoom in.
2. Selection graphic is offset up and to the right by several pixels
(Firefox 2)
3. When panning and zooming, sometimes I'll get an error in MapTip.js at
line 203, erroring out because this.oMapTipPosition.y is null. I'm not
sure what's happening here; whether I'm placing the mouse over a div
that's floating over the map, or if it's trying to query while the map div
isn't active?
The performance of tiled maps in Fusion is pretty decent though. I'd love
to be able to use this stuff!
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/469>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
