[mapguide-trac] #468: Fusion doesn't use tile cache for ajax
tiled maps
trac_mapguide at osgeo.org
Fri Feb 29 17:41:22 EST 2008
#468: Fusion doesn't use tile cache for ajax tiled maps
Reporter: zspitzer | Owner:
Type: defect | Status: closed
Priority: high | Milestone: 2.1
Component: Fusion | Version:
Severity: major | Resolution: invalid
Keywords: | External_id:
Changes (by jbirch):
* status: new => closed
* resolution: => invalid
Comment:
I've tested this against 2.0.0 Release, watching the net with Fiddler, and
have confirmed that with the above change the Fusion tiled maps call the
tiles. There are other defects though when using this type of map, which
I've added to #469
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/468#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
