[mapguide-trac] #469: Fusion Tiled Maps Issues
trac_mapguide at osgeo.org
Fri Feb 29 20:06:50 EST 2008
Reporter: jbirch | Owner:
Type: defect | Status: new
Priority: medium | Milestone:
Component: Fusion | Version: 2.0.0
Severity: major | Resolution:
Keywords: fusion, tiled | External_id:
Old description:
> Tiled maps in Fusion do not appear to be fully supported yet.
> To test these, modify Aqua's ApplicationDefinition.xml, changing to the
> map to MapsTiled\Sheyboygan, and setting SingleTile to false. All of
> these were tested in FireFox.
> 1. Zoom slider does not appear to initialize. Stays on closest zoom in.
> 2. Selection graphic is offset up and to the right by several pixels
> (Firefox 2)
> 3. When panning and zooming, sometimes I'll get an error in MapTip.js at
> line 203, erroring out because this.oMapTipPosition.y is null. I'm not
> sure what's happening here; whether I'm placing the mouse over a div
> that's floating over the map, or if it's trying to query while the map
> div isn't active?
> 4. The Legend panel does not "work" with tiled layers properly. It will
> need some kind of special treatment to only display a check-box at the
> parent level, etc.
> 5. Specifying a tile size smaller than 300x300 in the MapGuide server
> config makes small outlines appear around the images. Perhaps the OL
> code is hard-coded to 300x300?
> The performance of tiled maps in Fusion is pretty decent though. I'd
> love to be able to use this stuff!
New description:
(Firefox 2)
that's floating over the map, or if it's trying to query while the map div
isn't active?
parent level, etc.
config makes small outlines appear around the images. Perhaps the OL code
6. For some reason, on the Demo server I'm getting 401 responses for some
tiles, followed by 200 responses. Huh?
http://mapguidebeta.osgeo.org/mapguide/fusion/templates/mapguide/slate_tiled/index.html
The performance of tiled maps in Fusion is pretty decent though. I'd love
Comment (by jbirch):
Added authentication issue.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/469#comment:3>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
