[mapguide-trac] #401: Fix AdvancedPlacement handling
trac_mapguide at osgeo.org
Wed Jan 16 16:55:58 EST 2008
Reporter: waltweltonlair | Owner: waltweltonlair
Type: defect | Status: new
Priority: high | Milestone:
Component: General | Version:
Severity: minor | Keywords:
External_id: 1036670 |
The !LayerDefinition schema supports an !AdvancedPlacement element on
!TextSymbol. This element determines whether labels are positioned using
an advanced placement algorithm. In particular, it determines if labels
on polylines follow the contour of the polyline.
In prior versions of !MapGuide this element has never been persisted, even
though the default behavior was to enable the advanced placement algorithm
for polyline labels. Going forward we want to start using this element to
control whether advanced placement occurs, while at the same time allow
legacy maps to draw unchanged.
Old maps are missing the !AdvancedPlacement element, and therefore the
lack of this element implies the advanced placement option be enabled by
default. This was already fixed in changeset 2681. In order to specify
that a map not use advanced placement, we will tweak the behavior of the
!ScaleLimit subelement. If this element is 0.0 or less then advanced
placement is off. If greater than 0.0 then advanced placement is on. We
must update !MdfParser to always save the !AdvancedPlacement / !ScaleLimit
elements.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/401>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
