[mapguide-trac] #405: Installation location other than the default
trac_mapguide at osgeo.org
Thu Jan 24 13:42:37 EST 2008
Reporter: jnel | Owner:
Type: enhancement | Status: new
Priority: low | Milestone:
Component: General | Version:
Severity: major | Resolution:
Keywords: | External_id:
Comment (by jbirch):
I agree that it would be nice to see a dialog to choose the installation
location during !MapGuide setup.
There is actually a command-line switch that you can use to specify the
install location for both the server and the web extensions. It's worked
in my experience with the bundled Apache installation mode, but it is not
documented or (obviously) supported...
Basically, you can do something like:
MgServerSetup-2.0.0.exe /v"INSTALLDIR=\"D:\MyFolder\""
You can find other parameters availble here:
http://helpnet.macrovision.com/robo/projects/helplibdevstudio9/IHelpSetup_EXECmdLine.htm
http://helpnet.macrovision.com/robo/projects/helplibdevstudio9/IHelpPropReference.htm
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/405#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
