[mapguide-trac] #413: Feature Joins totally broken
trac_mapguide at osgeo.org
Mon Jan 28 22:58:04 EST 2008
Reporter: jng | Owner:
Type: defect | Status: new
Priority: high | Milestone: 2.0
Component: General | Version: 2.0.0
Severity: blocker | Keywords: feature join
External_id: |
I migrated one of our datasets to MGOS 2.0.0 RC1 and noticed the layers
that are joined to an external database failed to render, where it
previously rendered fine under v1.2.0
As a test I did a simple join of the Sheboygan parcels and its parcel
database in MapGuide Studio 2009 beta (from the sample data), created a
layer that is themed from one of the joined attributes (RTYPE) and noticed
that it too failed to render.
I repeated the same process in MapGuide Studio 2008 (MGOS 1.2.0), and the
joined parcels did render as expected.
Looking at the error logs, I found lots of these messages...
<2008-01-29T17:40:35> Administrator
Error: Failed to stylize layer: LayerDefinition3
An unclassified exception occurred.
StackTrace:
- MgMappingUtil.StylizeLayers line 781 file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_19.3\mgdev\server\src\services\mapping\MappingUtil.cpp
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/413>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
