[mapguide-trac] #414: Fusion Preview of Map with coordinate system transformation generates unclassified exception
MapGuide Open Source trac_mapguide at osgeo.org
Wed Jan 30 21:58:19 EST 2008
   Reporter:  stevedang          |       Owner:
       Type:  defect             |      Status:  new
   Priority:  medium             |   Milestone:  2.0
  Component:  Rendering Service  |     Version:  2.0.0
   Severity:  major              |    Keywords:
External_id:  1036667            |
 A map containing a single layer that transforms the LL84 data to a local
 coordinate system that should cover the data bounds. However when
 previewed using the fusion viewer a stylization unclassified exception
 occurs on the server possibly putting the server in a bad state.
 Testing indicates it's a problem with the composite line styles that
 causes the exception.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/414>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
