[mapguide-trac] #616: Incorrect XML definition
trac_mapguide at osgeo.org
Fri Jul 4 01:57:20 EDT 2008
Reporter: jnel | Owner: ksgeograf
Type: defect | Status: new
Priority: medium | Milestone:
Component: Maestro | Version: 2.0.1
Severity: minor | Keywords: Parameteroverrides XML Structure
External_id: |
When i create a compound symboldefinition in Maestro, the XML provided in
the Autodesk document
(building_symbol_libraries_with_autodesk_mapguide_enterprise_2009.pdf) for
the hospital symbol is:
<SimpleSymbolDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-
instance"
xsi:noNamespaceSchemaLocation="SymbolDefinition-1.0.0.xsd"
version="1.0.0">
<Name>Hospital</Name>
<Description>International Hospital Symbol</Description>
<Graphics>
<Path>
<Geometry>M -2.5,2.5 H 2.5 V -2.5 H -2.5 Z</Geometry>
<FillColor>FF0000FF</FillColor>
<LineColor>FFFFFFFF</LineColor>
<LineWeight>0.75</LineWeight>
<LineWeightScalable>false</LineWeightScalable>
</Path>
<Path>
<Geometry>M -1.0,1.25 V -1.25 Z M 1.0,1.25 V -1.25 Z M -1.0,0.0 H 1.0
Z</Geometry>
</Path>
</Graphics>
<PointUsage/>
'''<ParameterDefinition/>'''
</SimpleSymbolDefinition>
On the second last line the parameterdefinition structure is incorrect.
When i generate the layerdefinition in Maestro I provide it the following
<CompositeSymbolization>
<SymbolInstance>
<ResourceId>Library://sys/Symbols/Road.SymbolDefinition</ResourceId>
<ParameterOverrides>
</ParameterOverrides>
</SymbolInstance>
</CompositeSymbolization>
I Validate and save this definition, without error.
When I look at the xml again It is:
<CompositeRule>
<LegendLabel />
<SymbolInstance>
<ParameterOverrides />
</SymbolInstance>
</CompositeRule>
I Believe the ParameterOverrides is illegal xml structure
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/616>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
