[mapguide-trac] #617: Utf8 support for Selection (attribute
value display)
trac_mapguide at osgeo.org
Wed Jul 9 12:09:09 EDT 2008
#617: Utf8 support for Selection (attribute value display)
Reporter: poulet1212 | Owner: chrisclaydon
Type: defect | Status: closed
Priority: medium | Milestone:
Component: Fusion | Version: 2.0.1
Severity: major | Resolution: fixed
Keywords: | External_id:
Comment (by poulet1212):
Hi pagameba,
at a firat approach I would like to say that
utf8_decode($value);
and
htmlentities($value,ENT_COMPAT,'UTF-8');
do the same (only regarding the charset naturally).
But, if we do not handle the charset directly when getting a String
property from the FeatureReader, we must do that later.
So, is it better to do that when getting the string from featurereader
like proposed in this ticket or is it better to handle the charset later
like in ticket 83?
I think it would be fine to do that when getting the string from
featurereader because other scripts might use this utility function.
Regards
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/617#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
