[mapguide-trac] #625: Add exception handling when a cached FDO
connection is being removed from the cache
trac_mapguide at osgeo.org
Wed Jul 9 14:34:38 EDT 2008
#625: Add exception handling when a cached FDO connection is being removed from
the cache
Reporter: brucedechant | Owner:
Type: defect | Status: new
Priority: medium | Milestone: 2.1
Component: Server | Version: 2.0.1
Severity: minor | Keywords:
External_id: |
There is no exception handling when a FDO connection is closed while
attempting to remove it from the cache. If an exception occurs during the
closing of a FDO connection for whatever reason the FDO connection is not
removed from the cache.
If the closing of the FDO connection fails the FDO connection should still
be removed from the cache.
Examples of why the closing of a FDO connection might cause an exception:
- The underlying feature source of the FDO connection has terminated the
connection on its own by a DBA
- A network cable is unplugged and the connection is lost
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/625>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
