[mapguide-trac] #608: Occasional MgPremissionDeniedException
trac_mapguide at osgeo.org
Mon Jul 14 08:32:50 EDT 2008
Reporter: andrewd | Owner: ksgeograf
Type: defect | Status: assigned
Priority: high | Milestone:
Component: Maestro | Version:
Severity: major | Resolution:
Keywords: | External_id:
Comment (by andrewd):
Ya, I read that post, and though it sounded pretty similar.
I'm guessing that you could recreate the problem if you set up a map in a
library folder with, and make that folder (and it's contents) accessible
only by Administrator and 1 other user. Then view the map in your browser,
logging in as that other user - then try to connect to the site using
Maestro - using Administrator.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/608#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
