[mapguide-trac] #318: Stream IO exception : "TCP/IP protocol is
mismatched between the Server and Web Extensions"
trac_mapguide at osgeo.org
Mon Jul 14 22:28:55 EDT 2008
#318: Stream IO exception : "TCP/IP protocol is mismatched between the Server and
Web Extensions"
Reporter: fvanderbiest | Owner:
Type: defect | Status: reopened
Priority: medium | Milestone:
Component: General | Version: 2.0.1
Severity: major | Resolution:
Keywords: exception TCP/IP | External_id:
Comment (by zspitzer):
Just that message I included, nothing else.
I was seeding a tiled map using openlayers, the only calls being made
where GETTILE against the server using SHP files
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/318#comment:7>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
