[mapguide-trac] #637: Maestro: Checking Point/Line or Area should automatically add a new display style
MapGuide Open Source trac_mapguide at osgeo.org
Fri Jul 18 06:40:27 EDT 2008
style
   Reporter:  ksgeograf    |       Owner:  ksgeograf
       Type:  enhancement  |      Status:  new
   Priority:  high         |   Milestone:
  Component:  Maestro      |     Version:
   Severity:  trivial      |    Keywords:
External_id:               |
 When checking the "Display lines" checkbox on a layer, Maestro should add
 a default style to the list, if it is otherwise empty.
 This should be done for points and areas as well.
 Adding this will make it much easier for newcomers to understand how
 styling works in MapGuide.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/637>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
