[mapguide-trac] #614: Selection against a joined feature source
	returns an extra feature
    trac_mapguide at osgeo.org
    Wed Jul 30 17:09:42 EDT 2008
#614: Selection against a joined feature source returns an extra feature
 Reporter:  mgluobin  |         Owner:
     Type:  defect    |        Status:  new
 Priority:  high      |     Milestone:  2.1
Component:  General   |       Version:  2.0.1
 Severity:  blocker   |    Resolution:
 Keywords:            |   External_id:
Comment (by brucedechant):
 I cannot reproduce this with a SHP to Access join using the current trunk
 code. (My dataset was just sample world countries)
 I used the following filter on the layer: (Key is from the primary feature
 source)
 Key  >=  'CA'
 It only returned Macedonia and nothing else when I entered "AC" into the
 query.
 Can you provide the filter you are using that causes this issue?
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/614#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
