[mapguide-trac] #565: Add support for editing Xml config files
on resources
trac_mapguide at osgeo.org
Fri Jun 13 13:21:54 EDT 2008
#565: Add support for editing Xml config files on resources
Reporter: ksgeograf | Owner: ksgeograf
Type: enhancement | Status: assigned
Priority: medium | Milestone:
Component: Maestro | Version:
Severity: major | Resolution:
Keywords: | External_id:
Changes (by jbirch):
* type: defect => enhancement
Comment:
Note, this is partially implemented (for Rasters, is this the same
mechanism used for joins, CS overrides?) but not yet for WMS. Should I
create a separate item for WMS overrides and close this?
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/565#comment:2>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
