[mapguide-trac] #606: Maestro: Consider adding a "Repointer"
function
trac_mapguide at osgeo.org
Fri Jun 13 13:41:38 EDT 2008
#606: Maestro: Consider adding a "Repointer" function
Reporter: jbirch | Owner: ksgeograf
Type: enhancement | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Resolution:
Keywords: | External_id:
Old description:
> It would be useful to be able to click on a Layer and say "Point all maps
> that reference this layer to this other layer instead", and the same for
> MapDefinitions (and WebLayouts/ApplicationDefinitions).
> Similar option would be cool for data connections as well, but much more
> complex because of potential for mis-matched schemas. To implement this
> you would also need to have a validity checker for layer definitions,
> allowing the user to list layers with invalid definitions, and visually
> see which properties are invalid when the layer is open. MapGuide Studio
> (at least up to 2008?) just resets the layer definition when there are
> different schemas regardless of whether it would invalidate the layer
> definition, but this is not a desirable behaviour.
New description:
!MapDefinitions (and !WebLayouts/ApplicationDefinitions). This would
allow for simple testing of new layer definitions before swapping into
live maps.
see which properties are invalid when the layer is open. !MapGuide Studio
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/606#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
