[mapguide-trac] #601: MapGuide Maestro: image tiling in
composite mode is not working
trac_mapguide at osgeo.org
Tue Jun 17 12:11:39 EDT 2008
#601: MapGuide Maestro: image tiling in composite mode is not working
Reporter: dumas65 | Owner: ksgeograf
Type: defect | Status: new
Priority: low | Milestone:
Component: Maestro | Version:
Severity: trivial | Resolution:
Keywords: | External_id:
Comment (by dumas65):
Yes and no. In dataconnection properties I used - 'Single file or folder'.
In this case coordinates are detected.
But if I use 'composite' for same raster, coordinates are not detected.
Directories have no spaces, I even tried directly from drive F:/
by the way, it was impossible to add rasters from alias in composite mode.
I chose browse alias, then selected files, after pressing OK window still
was empty.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:11>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
