[mapguide-trac] #601: MapGuide Maestro: image tiling in
	composite mode is not working
    trac_mapguide at osgeo.org
    Wed Jun 18 05:13:08 EDT 2008
#601: MapGuide Maestro: image tiling in composite mode is not working
 Reporter:  dumas65  |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  trivial  |    Resolution:
 Keywords:           |   External_id:
Changes (by ksgeograf):
  * status:  new => assigned
Comment:
 Ok. I see there is a bug/weird behavior when you select a single file,
 rather than a folder. I will fix that.
 I will try to reproduce.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/601#comment:13>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
