[mapguide-trac] #609: Layer previews not zooming to extents
    trac_mapguide at osgeo.org
    Wed Jun 25 12:31:44 EDT 2008
 Reporter:  andrewd  |         Owner:  ksgeograf
     Type:  defect   |        Status:  assigned
 Priority:  low      |     Milestone:
Component:  Maestro  |       Version:
 Severity:  minor    |    Resolution:
 Keywords:           |   External_id:
Comment (by andrewd):
 1.0.8.15762. Once you said that, I downloaded the preview (r3216) - but
 then after that, you posted on the mailing list that there's a real
 release of it now.  So I took off the preview, and put on the release -
 now I'm at 1.0.8.27399 and I do see the new button!
 Ok - so my spatial context info for the layersources that aren't working
 is as follows:
 <?xml version="1.0"?>
 <FdoSpatialContextList xmlns:xsi="http://www.w3.org/2001/XMLSchema-
 instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"
 xsi:noNamespaceSchemaLocation="FdoSpatialContextList-1.0.0.xsd">
   <ProviderName />
 </FdoSpatialContextList>
 Now the question is, why is it blank? Looking at the coord overrides,
 there IS a difference between the 2 layersources. Oddly enough, if I edit
 the XML of these 2, the one that works has no
 <SupplementalSpatialContextInfo>...But I know it's there, because 1)
 Maestro sees it when I refresh, and 2) The layer works fine.
 It looks like the one that works was maybe made with Studio (the override,
 I mean) and the one that doesn't was made with Maestro. I'm not sure
 though - but the "source" coord override that doesn't work is named
 "Oblique_Stereographic", which seems to be what Maestro puts in - the one
 that works is called "CANST-NB83-CSRS"...the 2 layers do get projected
 correctly though.
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/609#comment:11>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
