[mapguide-trac] #539: Implement CLIENTIP and CLIENTAGENT
tracking in the Server's Access.log
trac_mapguide at osgeo.org
Thu May 1 18:47:43 EDT 2008
#539: Implement CLIENTIP and CLIENTAGENT tracking in the Server's Access.log
Reporter: tonyfang | Owner: tonyfang
Type: defect | Status: closed
Priority: medium | Milestone: 2.1
Component: Web API | Version: 2.0.0
Severity: minor | Resolution: fixed
Keywords: | External_id:
Comment (by tonyfang):
Just for logging.
As it says in the Description, the Map Admin was already sending these
parameters to the server and getting them logged in the Access.log.
The submissions associated with this ticket complete the work for the rest
of the applications (Ajax, Web Tier test pages, Schema Report). And also
implements the REMOTE_ADDR IP checking in the Apache/ISAPI/CGI agents for
HTTP requests.
I figured REMOTE_ADDR is the most useful IP information for the
Access.log. If the user is behind a proxy, the IP behind the proxy may not
be very meaningful to the Access.log.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/539#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
