[mapguide-trac] #175: Unmanaged SHP File Locations Performance
Issues as More Files get Added
trac_mapguide at osgeo.org
Fri May 2 10:42:58 EDT 2008
#175: Unmanaged SHP File Locations Performance Issues as More Files get Added
Reporter: cgountanis | Owner:
Type: defect | Status: reopened
Priority: high | Milestone:
Component: Server | Version: 2.0.0
Severity: major | Resolution:
Keywords: fdo,mapguide 1.2 beta 2, shp, dbf | External_id: 940227
Changes (by zspitzer):
* status: closed => reopened
* version: 1.2.0 => 2.0.0
* resolution: fixed =>
Comment:
I just encountered this issue with MG 2.0 on Linux. Performance was
terrible until I
created a single featureSource for each SHP and then it started to fly
along.
here is the file list, with the problem i had only the rail and road shps
being used and no labelling. I only solved it because i remembered reading
this bug a while ago :)
total 55M
8.0K tr_air_infra_area_centroid.dbf
8.0K tr_air_infra_area_centroid.idx
8.0K tr_air_infra_area_centroid.prj
8.0K tr_air_infra_area_centroid.shp
8.0K tr_air_infra_area_centroid.shx
12K tr_air_infra_area_line.dbf
8.0K tr_air_infra_area_line.idx
8.0K tr_air_infra_area_line.prj
16K tr_air_infra_area_line.shp
8.0K tr_air_infra_area_line.shx
12K tr_air_infra_area_polygon.dbf
8.0K tr_air_infra_area_polygon.idx
8.0K tr_air_infra_area_polygon.prj
16K tr_air_infra_area_polygon.shp
8.0K tr_air_infra_area_polygon.shx
8.0K tr_airport_area_centroid.dbf
8.0K tr_airport_area_centroid.idx
8.0K tr_airport_area_centroid.prj
8.0K tr_airport_area_centroid.shp
8.0K tr_airport_area_centroid.shx
12K tr_airport_area_line.dbf
8.0K tr_airport_area_line.idx
8.0K tr_airport_area_line.prj
12K tr_airport_area_line.shp
8.0K tr_airport_area_line.shx
8.0K tr_airport_area_polygon.dbf
8.0K tr_airport_area_polygon.idx
8.0K tr_airport_area_polygon.prj
12K tr_airport_area_polygon.shp
8.0K tr_airport_area_polygon.shx
20K tr_airport_infrastructure.dbf
8.0K tr_airport_infrastructure.idx
8.0K tr_airport_infrastructure.prj
12K tr_airport_infrastructure.shp
8.0K tr_airport_infrastructure.shx
8.0K tr_ferry_route.dbf
8.0K tr_ferry_route.idx
8.0K tr_ferry_route.prj
8.0K tr_ferry_route.shp
8.0K tr_ferry_route.shx
200K tr_rail.dbf
40K tr_rail.idx
20K tr_rail_infrastructure.dbf
8.0K tr_rail_infrastructure.idx
8.0K tr_rail_infrastructure.prj
8.0K tr_rail_infrastructure.shp
8.0K tr_rail_infrastructure.shx
8.0K tr_rail.prj
200K tr_rail.shp
16K tr_rail.shx
24M tr_road.dbf
1.8M tr_road.idx
8.7M tr_road_infrastructure.dbf
1.5M tr_road_infrastructure.idx
8.0K tr_road_infrastructure.prj
1.4M tr_road_infrastructure.shp
400K tr_road_infrastructure.shx
2.6M tr_road_locality.dbf
3.0M tr_road_locality_section.dbf
8.0K tr_road.prj
11M tr_road.shp
492K tr_road.shx
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/175#comment:18>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
