[mapguide-trac] #545: Categories.txt is in the wrong place
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 5 16:37:14 EDT 2008
   Reporter:  ksgeograf  |       Owner:
       Type:  defect     |      Status:  new
   Priority:  medium     |   Milestone:  2.1
  Component:  Server     |     Version:  2.0.0
   Severity:  major      |    Keywords:  categories.txt PROJ_LIB nad coordinate systrm
External_id:             |
 I have a Danish WinXP IIS .Net installation of MapGuideOS 2.0.
 The previous version was uninstalled before installing the current.
 Categories.txt is located in:
 {{{C:\Programmer\MapGuideOpenSource2.0\Server\Bin\}}}
 but the PROJ_LIB environment variable is set to:
 {{{C:\Programmer\MapGuideOpenSource2.0\Server\nad}}}
 This means that only the "Arbitrary XY" coordinate systems are avalible.
 There are other files in the "nad" folder.
 Copying the file into the expected location does not show the missing
 coordinate system categories.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/545>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
