[mapguide-trac] #539: Implement CLIENTIP and CLIENTAGENT tracking in the Server's Access.log
MapGuide Open Source trac_mapguide at osgeo.org
Mon May 5 21:01:08 EDT 2008
 Reporter:  tonyfang  |         Owner:  tonyfang
     Type:  defect    |        Status:  reopened
 Priority:  medium    |     Milestone:  2.1
Component:  Web API   |       Version:  2.0.0
 Severity:  minor     |    Resolution:
 Keywords:            |   External_id:
Changes (by tonyfang):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Jason: Thanks for the tip!
 I looked a little more into HTTP_CLIENT_IP and XFF -- that seems much
 better than simply using REMOTE_ADDR. So the code will be changed to the
 following:
 function GetClientIp()
     $clientIp = '';
     if (array_key_exists('HTTP_CLIENT_IP', $_SERVER)
         && strcasecmp($_SERVER['HTTP_CLIENT_IP'], 'unknown') != 0)
         $clientIp = $_SERVER['HTTP_CLIENT_IP'];
     else if (array_key_exists('HTTP_X_FORWARDED_FOR', $_SERVER)
         && strcasecmp($_SERVER['HTTP_X_FORWARDED_FOR'], 'unknown') != 0)
         $clientIp = $_SERVER['HTTP_X_FORWARDED_FOR'];
     else if (array_key_exists('REMOTE_ADDR', $_SERVER))
         $clientIp = $_SERVER['REMOTE_ADDR'];
     return $clientIp;
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/539#comment:6>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
