[mapguide-trac] #548: Apache restart required sometimes to start mapguide
MapGuide Open Source trac_mapguide at osgeo.org
Thu May 8 20:42:59 EDT 2008
   Reporter:  zspitzer  |       Owner:
       Type:  defect    |      Status:  new
   Priority:  medium    |   Milestone:
  Component:  Server    |     Version:  2.0.0
   Severity:  major     |    Keywords:
External_id:            |
 I have seen on both XP and Linux that often that mapguide will not restart
 until the apache service is restarted.
 It happens often after the mapguide service has crashed or has been
 killed.
 [root at gis bin]# ./mgserver.sh
 /usr/local/mapguideopensource/server/bin
 Running the server interactively as an application instead of as a
 service.
 (3085813440) Server starting...
 (3085813440) PROJ4 Coordinate System Library
 (3085813440) Port 2812 is not available, please try using a different
 port.
 Exception occurred in method MgServer.svc at line 595 in file Server.cpp
 (3085813440) - MgServer.svc line 595 file Server.cpp
 (3085813440) The connection is not open.
 Exception occurred in method MgSiteConnection.GetCurrentUserInfo at line
 382 in file System/UserInformation.cpp
 terminate called after throwing an instance of
 'MgConnectionNotOpenException*'
 ./mgserver.sh: line 7:  1845 Aborted                 ./mgserver run
 after restarting apache, mapguide will start sucessfully
Ticket URL: <http://trac.osgeo.org/mapguide/ticket/548>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac mailing list
